Airport-77
Jun 21, 2019Aspirant
Orbi RBR50 keeps disconnecting from internet and shows solid magenta.
I have been using Orbi RBR50 with 2 satellites RBS50. It has been great for more than a year. Recently in last 6 months I see my RBR50 keeps disconnecting from the internet at regular intervals, about...
Jun 22, 2019Guru - Experienced User
Has a factory reset and setup from scratch been performed since the FW was updated?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Airport-77
Jun 22, 2019Aspirant
I did a factory reset last night around 10:30 PM. It worked find till this morning around 7:20 AM. I restarted modem , router and satellites. It is working fine since then.
As far as Modem I have the Arris SB8200.
My home is about 2100 sqft and I have the devices about 30 ft apart. Rest all the settings you recommended are already that.
I have one RBR50 and 2 RBS50
- FURRYe38Jun 23, 2019Guru - Experienced User
Hopefully will keep working after restart of entire system. Let us know if something else happens.
Airport 77 is a good movie.
Enjoy. :smileywink:
- Airport-77Jun 23, 2019AspirantIt is a good movieđ
Unfortunately it is still happening. In more research I think it is my Arris SB8200 that's at fault. I am changing that to a Netgear CM1000. Let's see how that works.- FURRYe38Jun 23, 2019Guru - Experienced User
Possible bad modem. Try a reset on the modem if that option is available. Let us know if new CM modem resolves this. Seems like a modem issue.
