Airport-77
Jun 21, 2019Aspirant
Orbi RBR50 keeps disconnecting from internet and shows solid magenta.
I have been using Orbi RBR50 with 2 satellites RBS50. It has been great for more than a year. Recently in last 6 months I see my RBR50 keeps disconnecting from the internet at regular intervals, about...
Airport-77
Jun 22, 2019Aspirant
I did a factory reset last night around 10:30 PM. It worked find till this morning around 7:20 AM. I restarted modem , router and satellites. It is working fine since then.
As far as Modem I have the Arris SB8200.
My home is about 2100 sqft and I have the devices about 30 ft apart. Rest all the settings you recommended are already that.
I have one RBR50 and 2 RBS50
Jun 23, 2019Guru - Experienced User
Hopefully will keep working after restart of entire system. Let us know if something else happens.
Airport 77 is a good movie.
Enjoy. :smileywink:
- Airport-77Jun 23, 2019AspirantIt is a good movie😁
Unfortunately it is still happening. In more research I think it is my Arris SB8200 that's at fault. I am changing that to a Netgear CM1000. Let's see how that works.- FURRYe38Jun 23, 2019Guru - Experienced User
Possible bad modem. Try a reset on the modem if that option is available. Let us know if new CM modem resolves this. Seems like a modem issue.
- Airport-77Jun 23, 2019AspirantI think so too. All I need to do is remove the ethernet cable at the modem end that runs from modem to router and plug it back and it fixes it instantly.
