Airport-77
Jun 21, 2019Aspirant
Orbi RBR50 keeps disconnecting from internet and shows solid magenta.
I have been using Orbi RBR50 with 2 satellites RBS50. It has been great for more than a year. Recently in last 6 months I see my RBR50 keeps disconnecting from the internet at regular intervals, about...
Jun 23, 2019Guru - Experienced User
Hopefully will keep working after restart of entire system. Let us know if something else happens.
Airport 77 is a good movie.
Enjoy. :smileywink:
Airport-77
Jun 23, 2019Aspirant
It is a good movie😁
Unfortunately it is still happening. In more research I think it is my Arris SB8200 that's at fault. I am changing that to a Netgear CM1000. Let's see how that works.
- FURRYe38Jun 23, 2019Guru - Experienced User
Possible bad modem. Try a reset on the modem if that option is available. Let us know if new CM modem resolves this. Seems like a modem issue.
- Airport-77Jun 23, 2019AspirantI think so too. All I need to do is remove the ethernet cable at the modem end that runs from modem to router and plug it back and it fixes it instantly.
Besure LAN cable is good. CAT6 is recommended. Ya seems odd. Possible loss of handshake at the modem for some reason.
