Airport-77
Jun 21, 2019Aspirant
Orbi RBR50 keeps disconnecting from internet and shows solid magenta.
I have been using Orbi RBR50 with 2 satellites RBS50. It has been great for more than a year. Recently in last 6 months I see my RBR50 keeps disconnecting from the internet at regular intervals, about...
Airport-77
Jun 23, 2019Aspirant
It is a good movieđ
Unfortunately it is still happening. In more research I think it is my Arris SB8200 that's at fault. I am changing that to a Netgear CM1000. Let's see how that works.
Jun 23, 2019Guru - Experienced User
Possible bad modem. Try a reset on the modem if that option is available. Let us know if new CM modem resolves this. Seems like a modem issue.
- Airport-77Jun 23, 2019AspirantI think so too. All I need to do is remove the ethernet cable at the modem end that runs from modem to router and plug it back and it fixes it instantly.
- FURRYe38Jun 23, 2019Guru - Experienced User
Besure LAN cable is good. CAT6 is recommended. Ya seems odd. Possible loss of handshake at the modem for some reason.
