Denisea3465
Jan 29, 2021Aspirant
Orbi RBR50 keeps disconnecting several times a week
Apologies ahead of time because we are in Sweden and I am unsure of the names of things in English but the Swedish site has very little activity. We have a high-speed fiber?/cable connection that ...
vajim
Jan 29, 2021Master
what kind of modem do you have?
- Denisea3465Jan 29, 2021Aspirant
I am sorry that this is not in english but it is this one called a Zitius Inteno XG6846:
https://botkyrka.zmarket.se/Content/Images/uploaded/Inteno%20XG6846%20User%20Guide%20R2.pdf
This is what I referred to (apparently incorrectly) as a "switch" and where the Orbi Router, Xbox, and Telephone boxes are plugged in to Lan 1, Lan 2, and Lan 3 respectively.- vajimJan 29, 2021Master
Denisea3465 wrote:I am sorry that this is not in english but it is this one called a Zitius Inteno XG6846:
This is what I referred to (apparently incorrectly) as a "switch" and where the Orbi Router, Xbox, and Telephone boxes are plugged in to Lan 1, Lan 2, and Lan 3 respectively.Looks like Inteno XG6846 has a built in DHCP and acts as a gateway.
recommend contact your ISP for the proper settings so it'll work with a seperate router (Orbi)
you may have already seen this: https://www.192-168-1-1-ip.co/manuals/10413.pdf
there is discussion on how to set the XG6846 to access/router mode
- FURRYe38Jan 29, 2021Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
already answered.......thanks
