FordFamily
May 22, 2022Aspirant
Orbi RBR50 Keeps dropping internet help please.
Hello. I have been extremely happy with my Orbi system of 4 units with 3 satellites on a fiber service for over 2 years. I don’t even remember having any issues until recently and now they are non sto...
May 22, 2022Guru - Experienced User
Does the top ring on the RBR turn PINK when then happens?
Do both wired and wireless connections fail when this happens?
- FordFamilyMay 23, 2022AspirantFirmware is up to date V2.7.4.24
I do not know any details of modem or such but will report back when take a look at it. It’s a fiber system and when hook directly to it the connection is stable without Orbi in the chain.
Top ring turns magenta/pink when it drops internet.
The network does not fail when this happens with the other satellites. Just no internet connection. The satellites are still connected both wired and wireless.
Bests- FURRYe38May 23, 2022Guru - Experienced User
Please find the Modem or ONT brand and model information.
Ok, if PINK then the RBR failed to get ISP services from the ISP or the ISP service box/Modem/ONT.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Check with your ISP to see if any user account or VLAN configurations is needed or required.
- FordFamilyMay 23, 2022AspirantI just checked with them if it was on their end and that’s when I bypassed the Orbi and plugged straight into the ONT device and had stable connection while the Orbi wouldn’t connect.
I’ll get the ONT model and number for you though.
