Brongwyn
Jul 14, 2020Aspirant
Orbi RBR50 keeps dropping internet
My Orbi RBR50 (App: 2.5.4.1036, Firmware: v2.5.1.16) keeps dropping internet from the router. Satellites will show connected, but surfing the web gets spotty results (likely due to device switching ...
Jul 14, 2020Guru - Experienced User
Are you having problems getting internet all all or is this just the Orbi app showing the status of being disconnected?
- BrongwynJul 14, 2020Aspirant
It seems to be intermittent- some websites can be connected to fine, others throw 404 errors or similar. Once I factory reset and get all green lights, everything works fine to include websites which were previously having problems. Additionally, if I'm surfing from my phone: if I disconnect from wifi and use the 4G or 5G network- everything works great, but when connected to wifi- get mixed results like previously described and which is the same as from my desktop computer conncted via wifi (until I factory reset Orbi).
- FURRYe38Jul 14, 2020Guru - Experienced User
What Mfr and model is the main host router? There a built in router here by chance?
- BrongwynJul 20, 2020Aspirant
Don't know the Verizon Fios router model or firmware (the sticker on the back seems to have its default name and password only (in terms of useful info). As a precaution when they were setting it up, Verizon turned off their router's wifi to ensure it wouldn't conflict with Orbi. On the plus side, reliability has been very good for the past few days with no issues, so hopefully it was just a period of connection, line repairs, and such with Orbi having trouble re-connecting once the line was live again- but I'll continue to monitor and update as appropriate.
