Brongwyn
Jul 14, 2020Aspirant
Orbi RBR50 keeps dropping internet
My Orbi RBR50 (App: 2.5.4.1036, Firmware: v2.5.1.16) keeps dropping internet from the router. Satellites will show connected, but surfing the web gets spotty results (likely due to device switching ...
Mstrbig
Aug 21, 2020Master
Brongwyn wrote:Well, the problem has re-emerged and despite resetting the Fios router and reconfiguring it (to include turning off its wireless) and resetting my Orbi multiple times, the main Orbi hub continues to show a red dot, though the satellites show green. The unfortunate downside to this is that many web pages throw 404 errors and the connection is spotty. Not sure if there is a way to turn off my main Orbi hub wifi and just rely upon my two satellites for the wifi connection, but anything at this point would be helpful. Thank you all!
Can you eliminate the FIOS router and connect directly to the ONT? This is how we connect Orbi to Frontier FIOS here.
Brongwyn
Aug 30, 2020Aspirant
I have now turned off the Verison Fios wireless, wrapped it in a faraday cage, and hard wired my Orbi RBR50 to it. Unless I am standing right next to the Orbi Router, it will not connect and shows that it is offline. It will not allow remote access either. It shows no (0) satellite connections (though throughout the house and across the yard, the signal is strong- only possible via satellites, since the hub is in the basement now). Can't get it to connect to a single satellite despite factory reset or anything else. I now have 4 satellites as options since a friend got fed up with Orbi dropping the connection and went with Google, so gave me their hardware. 3 of the 4 satellites seem to be connected, though you couldn't tell from the Orbi app (shows not connected and 0 satellites). Multiple factory resets seem to have no effect or positive movement. Any thoughts? Thinking of switching to Google since this is becoming so much of an issue, especially under the current telework environment.
- MstrbigAug 30, 2020Master
Brongwyn wrote:I have now turned off the Verison Fios wireless, wrapped it in a faraday cage, and hard wired my Orbi RBR50 to it. Unless I am standing right next to the Orbi Router, it will not connect and shows that it is offline. It will not allow remote access either. It shows no (0) satellite connections (though throughout the house and across the yard, the signal is strong- only possible via satellites, since the hub is in the basement now). Can't get it to connect to a single satellite despite factory reset or anything else. I now have 4 satellites as options since a friend got fed up with Orbi dropping the connection and went with Google, so gave me their hardware. 3 of the 4 satellites seem to be connected, though you couldn't tell from the Orbi app (shows not connected and 0 satellites). Multiple factory resets seem to have no effect or positive movement. Any thoughts? Thinking of switching to Google since this is becoming so much of an issue, especially under the current telework environment.
What is in a faraday cage?
When you say you reset, did you reconfigure it like it was new out of the box?
Did you try bypassing the router and going directly to the ONT with a NIC?
What does it look like through a web browser when you go to orbilogin.com?
