PapaR
Dec 17, 2020Follower
Orbi RBR50 keeps going offline. Need to press sync button to get back online.
Apr 01, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
