bobsale789
Jul 25, 2023Aspirant
Orbi rbr50 keeps turning off mutliple times of the day, turning magenta sometimes
Hello We have had an orbi RBR50 for about 3 years, for a month now. It disconnects for 1-10 minutes. Sometimes the light says magenta. When I log into orbi router settings, it just says detecting, f...
Jul 26, 2023Guru - Experienced User
do hardwired devices drop?
What modem/gateway is it connected to?
bobsale789
Jul 26, 2023Aspirant
1:Yes by hardwired you mean devices connected with ethernet, if so yes
2: It is connected to a spectrum
- plemansJul 26, 2023Guru - Experienced User
when hardwired devices are dropping too, it makes me suspicious of the modem or the modem's connection.
Problem with spectrum is they've locked down their modems so you can't check their cable connections page anymore. So its tough for us to check it unless you have a 3rd party modem (and some of those get locked down too).
Spectrums first response whenever you ask them to check the line is "its not our line, its fine" or the blame the router.
- bobsale789Jul 26, 2023Aspirant
so what can we do then?
Will replacing the router possibly fix the problem? We called spectrum for support and they switched out there modem and a new one and they said that there line was fixed. - bobsale789Jul 26, 2023Aspirant
- michaelkenwardJul 28, 2023Guru - Experienced User
bobsale789 wrote:
2: It is connected to a spectrumOver the years Spectrum has supplied many different modems. So that is not enough detail to diagnose what might be happening.
Look on the modem for a make and model number.
Does it also have a row of Ethernet LAN ports on it somewhere? That is another indicator.
- bobsale789Jul 28, 2023Aspirant
The spectrum modem is 1 ethernet port. The we had the same issue with modems, not sure if they are the same model or not. But for 3 years we were using the same modem, no issues. Then there was, we called spectrum replaced the modem, and said our line is fine, it's your guyses.
- FURRYe38Jul 28, 2023Guru - Experienced User
If the top ring is turning PINK, while connected to the ISP modem and Online, this means there is a problem at the ISP modem or cabling between the modem and the RBR.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.You might update FW on the RBS then RBR as well:
