JodysCars
Apr 06, 2020Guide
Orbi RBR50 looses Internet several times a day
I have an Orbi RBR50 with 2 RBS50 satellites connected to a NG CM1000. I have Xfinity gigabit service. I have a NG GS308P installed after the router I installed it in September of 2019 (of coarse ...
- Retired_MemberApr 09, 2020
JodysCars wrote:
Correct, I went back to 2.3.5.30Nice :smileyhappy:
Apr 06, 2020Guru - Experienced User
Has the modem and RBR been powered OFF for 1 minute then back ON?
Is wired and wireless devices effected when this happens?
Are the RBS wireless or wired to the RBR?
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQ
Might try this when you get free time with the system...
JodysCars
Apr 06, 2020Guide
I powered off modem and RBR for 2 minutes
RBS is wireless to RBR
I live in a neighborhood but dont see anyone else's broadcast
No factory reset and setup since the original install 6 months ago
I made recomended changes. Lets see how it does.
- FURRYe38Apr 07, 2020Guru - Experienced User
Keep us posted. If nothing else, please try a factory reset and setup from scratch.
