he_sw
Mar 15, 2021Tutor
Orbi RBR50 loosing connection frequently
I have Orbi RBR50 (v 2.7.2.104) with 2 satellites it has been loosing connection every 2 hours. Works fine after a reboot The router is in router mode. Wow is the internet provider and there is no ...
Mar 15, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
