he_sw
Mar 15, 2021Tutor
Orbi RBR50 loosing connection frequently
I have Orbi RBR50 (v 2.7.2.104) with 2 satellites it has been loosing connection every 2 hours. Works fine after a reboot The router is in router mode. Wow is the internet provider and there is no ...
vajim
Mar 16, 2021Master
he_sw wrote:I have Orbi RBR50 (v 2.7.2.104) with 2 satellites it has been loosing connection every 2 hours. Works fine after a reboot
The router is in router mode. Wow is the internet provider and there is no issue from there end as when a laptop is hardwired to modem there is internet access.
Can someone pls help
Another firmware update failure
roll your firmware back
