dueas34343
Aug 21, 2020Aspirant
ORBI RBR50: Low Upload/Download speeds
Hi, I'm with Shaw in Canada. I have the Internet 300 plan. Noticed slow upload/download speeds when running Ookla's speed test on my iMac. Talked to Shaw support. They had me plug my modem in directl...
- Aug 21, 2020
Run the Speed test from the app or WEB GUI > This will give you the wired internet speed from the Orbi, through your ISP router.
Using the WEB GUI, go to Advanced, Advanced Setup, Wereless Settings:
Uncheck Enable 20/40 MHz Coexistence
Check Enable WMM (Wi-Fi multimedia) settings
Check Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices
Check Enable MU-MIMO
Uncheck Enable Fast Roaming
dueas34343
Hi,
Tested it on the iMac hardwired to modem (fast speeds), and then over WiFi (modem connected to Orbi -- slow speeds).
Mstrbig
Aug 21, 2020Master
dueas34343 wrote:Hi,
I read on another thread, where other Imac owners are experiencing the same slow WIFI. One user decided to try a USB based WIFI card and his speeds were excellent. He mentioned an issue with the Imac WIFI card.
- dueas34343Aug 21, 2020Aspirant
Interesting. I'll look into that. I'll admit, though, that I currently don't know what a "a USB based WIFI card" is.
Thanks.
- MstrbigAug 21, 2020Master
dueas34343 wrote:Interesting. I'll look into that. I'll admit, though, that I currently don't know what a "a USB based WIFI card" is.
Thanks.
Look up:
Wireless Usb Adapter For Mac
