dueas34343's avatar
dueas34343
ORBI RBR50: Low Upload/Download speeds
Hi, I'm with Shaw in Canada. I have the Internet 300 plan. Noticed slow upload/download speeds when running Ookla's speed test on my iMac. Talked to Shaw support. They had me plug my modem in directl...
  • Mstrbig's avatar
    Aug 21, 2020
    Run the Speed test from the app or WEB GUI > This will give you the wired internet speed from the Orbi, through your ISP router.
    Using the WEB GUI, go to Advanced, Advanced Setup, Wereless Settings:
    Uncheck Enable 20/40 MHz Coexistence
    Check Enable WMM (Wi-Fi multimedia) settings
    Check Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices
    Check Enable MU-MIMO
    Uncheck Enable Fast Roaming
