JDUB2002
Feb 25, 2020Aspirant
Orbi RBR50 Magenta ring after power loss, possible subnet issue with Xfinity and CM1000
Hello all, I have the RBR50 with 2 RBS50 satellites and one wall plug satellite. I have Xfinity internet service and use the Netgear CM1000 cable modem, which goes directly into my RBR50. Whe...
Feb 25, 2020Guru - Experienced User
Power OFF both CM modem and RBR. for 1 minute. Then power ON the CM modem and let it sync, should take about a minute or less. Then power ON the RBR. It should come to ready and the top ring LED should turn OFF.
If not, connect up a wired PC to the modem to make sure it's working and PC gets internet access directly with the modem.
JDUB2002
Another update, I have now connected my old Netgear WNDR3700 to the CM1000 and internet is working fine. I will now attempt to put the wndr3700 in bridge mode and connect the orbi to that and see what happens.
