SRNIJMU
Aug 30, 2020Aspirant
Orbi RBR50 magenta ring
Router: RBR50: Purchased May 19, 2019, Firmware updated within the last week. Modem: Comcast TG3482G Woke up this morning to no wifi, was working last night perfectly, no changes were made. Sol...
- Aug 31, 2020
SRNIJMU wrote:Just tired it again. Nothing. I didn't change any settings while bridge mode was off. I think I'm going to replace it but it's redicululus that a $500 router would die after a little over a year. I've bought many netgear routers over the years but never again.
If you have not done so, try a factory reset and reconfigure the Orbi router
Mstrbig
Aug 30, 2020Master
SRNIJMU wrote:Router: RBR50: Purchased May 19, 2019, Firmware updated within the last week.
Solid magenta ring on router
Rebooted router via app 2x
Rebooted modem via app 1x.
Rebooted router via unplug/replug
Rebooted modem via unplug/replug
Called comcast, they did reset and then turned off bridge mode.
Upstream to internet directly via Comcast router/modem is OK, so issue is with Orbi.
What do I do?
Did you reconfigure the Orbi router since you had bridge mode turned off?
- Jas23Aug 30, 2020AspirantSeems like Orbi has lost the ability to connect to internet this morning.
I just got off a call with Xfinity, thinking that it was their issue. But turns out, they have been getting calls from customers with Netgear routers all morning, complaining about loosing internet.
For now I have switched to an older router from a different company and the internet is back on.
Not sure how and where to complain about Netgear issue.- Jas23Aug 30, 2020AspirantSeems like it just came back online for me. Try yours, we might be back in business.
- SRNIJMUAug 31, 2020Aspirant
