Dirzl
Jun 04, 2019Initiate
Orbi RBR50 material became sticky
Hi all, this may not be related to technical issues, but I noticed my Orbi's exterior material has became sticky when I touch it. Has anyone else encountered this issue ?
CTcat
May 02, 2020Initiate
I have two orbi devices. One which has never received direct sunlight (not stick at all. still velvet to the touch) and the other which has received direct sunlight on its upper half (sticky and now collecting dust and other debris). Have been dusting and trying to wipe clean for months. Went on line and saw various remedies includling the ascetone/sanding suggestion. No way for me but clever idea.
My partial solution; use a clean white cloth and white household vinegar to gently clean with soft strokes in one direction until debris and dust are collected into a little gummy mess. Then use a toothpick to pick the gummy mess up and discard.
It will not correct the sticky situation but it looks a little better.
This is only a partial solution. If Netgear is sending replacements (at least one user got one) that do not have the velvet, rubbery finish, please let me know. I will gladly experiment with the finish. I am on Corona-time.
- skamelSep 05, 2020Initiate
Jumping on the sticky Orbi bandwagon... Satellite partially exposed to sun has become one big messy dust attracting gunk covered box... Beyond warranty period, so not thinking of exchange - so looking for ideas to clean up the sticky stuff and prevent further deterioration... Living in So Cal...
