Dirzl
Jun 04, 2019Initiate
Orbi RBR50 material became sticky
Hi all, this may not be related to technical issues, but I noticed my Orbi's exterior material has became sticky when I touch it. Has anyone else encountered this issue ?
mcC704
Sep 24, 2021Aspirant
I found using auto polishing compound (I have Turtle Wax brand), the smudges and some of the stickiness came off. Apply generously, rub hard with a soft sponge intended for auto paint, and wipe off with a soft towel before the compound begins to dry. Not perfect, but a decent appearance afterwards. Likely will have to repeat periodically to maintain in the face of this obvious factory defect. If I handle the units (have router and 3 satellites all affected), I make sure my hands are clean, wearing nitrile exam gloves, and try and not grip the bodies.
