RikParr73
Dec 05, 2023Aspirant
Orbi RBR50 Mesh Slow speeds when connected to Virgin Media Hub 5
Hi all Running 1 x RBR50, 2 x RBR30 and 1 x Orbi Extender. I have VM Huib 5 and 1Gbps package. RBR 50 in Router mode and Hub 5 in Modem mode. All was running fine for a month or so since upgradin...
- Dec 05, 2023
Be sure your using a good quality LAN cable between the modem and router. CAT6A is recommended.
What is the connection rate seen on the RBRs web page under Advanced tab/Show Stats for the WAN port connected to the ISP modem? 100 or 1000Mbps?
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Any Wifi Neighbors near by? If so, how many?Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
RikParr73
Thanks for your reply.
Did this VM activity involve your physical Hub 5 ? - I suspect so as when running diagnostics on their app it said to reset the Hub 5 - Which I have done (twice). I have also reset the Orbi.
Since you can connect directly to the VM Hub and get 700Mb, what happens when the same device is connected to an Orbi LAN port?
Ok, at the time of writing this when connecting directly to the 2.5gbps port on the back of the Hub 5 I get 383mbps. When connecting to any other port on the back of the Hub 5 I get 90mbps.
When connected directly to the Orbi I get 90mbps in every port (apart from the yellow internet port of course). All Wi-Fi devices will only run at 90mbps max. My external IP has changed but that doesn't affect anything i'm sure. I have port forwarding set up for my CCTV and that is the only config I have on the Orbi system that differs from standard
Dec 05, 2023Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
