RikParr73
Dec 05, 2023Aspirant
Orbi RBR50 Mesh Slow speeds when connected to Virgin Media Hub 5
Hi all Running 1 x RBR50, 2 x RBR30 and 1 x Orbi Extender. I have VM Huib 5 and 1Gbps package. RBR 50 in Router mode and Hub 5 in Modem mode. All was running fine for a month or so since upgradin...
- Dec 05, 2023
Be sure your using a good quality LAN cable between the modem and router. CAT6A is recommended.
What is the connection rate seen on the RBRs web page under Advanced tab/Show Stats for the WAN port connected to the ISP modem? 100 or 1000Mbps?
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Any Wifi Neighbors near by? If so, how many?Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
CrimpOn
Dec 05, 2023Guru - Experienced User
This is very strange (and not consistent with message number 1, which reported 700Mbps connected to the Hub 5).
A naive person, such as myself, would assume that contracting for 1 gigabit service would result in a speed of "very close" to 1 gigabit. Probably higher than 700Mbps, and definitely higher than 383Mbps.
The WAN (yellow) port on the Orbi router is connected to which port on the Hub 5?
(Hint: if the Orbi is connected to a LAN port which produced only 90Mbps, then the Orbi would also get 90Mbps and thus anything connected to the Orbi, either wired or WiFi, would get at most 90Mbps.)
One easy diagnostic is to open the Orbi web interface, navigate to the Advanced Tab home page, and click on Show Statistics. This will report the speed that the Orbi Ethernet module has negotiated with the Ethernet module on the Hub 5. Wikipedia explains how the Ethernet hardware negotiates the maximum speed supported by both devices:
https://en.wikipedia.org/wiki/Autonegotiation
What device was wired to the Hub 5 ports to measure speed?
RikParr73
Thanks, there is an issue with my ISP in my area at the moment, hence the speeds I think - but as per my other post I have found the issue to be the cat5 cable. I'm confused as it's been working fine up until the works that took place, or unless I'm mistaken - but swapping the cable has fixed it - thanks.
