mrwkbrdr
Sep 11, 2019Star
Orbi RBR50 mobile ph WiFi calling
Started noticing after SW v2.3.5.30 That my household 4 IPhones will call and connect with WiFi calling enabled, however once the other party answers, you can hear them but they are unable to hear y...
Sep 11, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
