ygarti
Feb 24, 2020Aspirant
ORBI RBR50 multiple wifi disconnection
Hi All, i am having some issues with RBR50 every few hours my wifi is diconnect for a few secondes and return back I thought that the problem was with the RBS50 so i disconnect it and i was s...
ygarti
Hi
i am using V2.3.5.30 which is offical FW (as far as i know)
i did it using the Orbi admin page (i didn't download anything or at least i don't rember)
i tried every solution that i found but nothing worked
any sugestion i will be glad to try becuse right now the situation is not great :)
Feb 24, 2020Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
My RBK50 is working on with the above suggestions and on v2.5.1.8.
ygarti wrote:Hi
