pseizure2000
May 24, 2020Tutor
Orbi RBR50 nearly constant reboots
I've had this router for over a year now, and I've always had minor issues with it rebooting on it's own. The entire thing goes down, including my ethernet to my computer. But for the past few months...
CrimpOn
May 24, 2020Guru - Experienced User
You mention manually loading various firmware.
Have you done a "Factory Reset" after updating firmware?
https://www.youtube.com/watch?v=cMw4ePACgc4
pseizure2000
May 24, 2020Tutor
CrimpOn Yeah sorry I forgot to type this up the second time after it rebooted again and I lost everything I wrote :\
Yep I've factory reset a few times. Even a 30-30-30 reset. Once it rebooted within minutes of the reset.
- FURRYe38May 26, 2020Guru - Experienced User
You can try Voxels FW for Orbi:
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1883615#
You can revert back to stock FW if it doesn't work out for you.
pseizure2000 wrote:Yeah sorry I forgot to type this up the second time after it rebooted again and I lost everything I wrote :\
- pseizure2000May 26, 2020Tutor
Thanks, I may try this if my next hail mary doesn't work. I'm gonna take it to my mother's this weekend. They have terrible coverage there, but importantly a different modem and ISP. If the issue is with my home setup, it'll definitely show there. For the time being I'm using old reliable (an TP-Link Archer C9) for my router, it's as stable as the Egyptian pyramids. I only switched to this because my new house is a 2 story 110 yr old with plaster and mesh and a shotgun style building so super long and narrow but only 1888 sqft. I can stomach an investment into a new modem if I need to. The old SB6141 was great but I think it has reached the max limits of my current broadband plan.
Yes would be a good test to see if the system works at a different location.
Ya, maybe time for a new modem at some point.
Keep us posted.
