Thutchins's avatar
Thutchins
Follower
Jun 12, 2021
Orbi RBr50 need to completely restart account
I need to restart my Orbi from scratch. The email that I used years ago when setting up net gear account is no longer active. So I want to start all over and create a new account and setup my ORBI with that new account. Does a factory reset wipe all info from the unit so I can start new?
Thanks!
1 Reply
  • CrimpOn's avatar
    CrimpOn
    After a Factory Reset, the Orbi can be set up using the Orbi web interface (http://orbilogin.net) It does not use the Netgear account login at all.
