jhall0125
Aug 19, 2021Tutor
Orbi RBR50 Netgear Armor Failure
Hello, I have a Netgear Orbi RBR50 router. In January 2021 I bought the bitdefender netgear armor subscription from my router. I had troubles from the beginning it took almost 5 days for the Orbi t...
Aug 19, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Armor product. Most of the people who watch that forum are more likely to have experience with Armor and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
https://www.netgear.com/landings/armor
Good Luck.
jhall0125
Aug 19, 2021Tutor
Disregard sorry clicked wrong link thanks
