Elfnash
Apr 25, 2021Tutor
Orbi rbr50 network components change connection to satellite
some of my devices will switch from the main router to the satellite, causing communication between devices inconsistent. For instance, my lg tv will switch. The. When I mirror my iPhone to play musi...
Elfnash
Apr 25, 2021Tutor
Does this mean that every day when I turn the tv on it will search for a connection? Would it be better to leave the tv on all the time?
CrimpOn
Apr 25, 2021Guru - Experienced User
Elfnash wrote:Does this mean that every day when I turn the tv on it will search for a connection? Would it be better to leave the tv on all the time?
My understanding is that the tv should select the same access point every time. Surely one of them provides a better signal to the tv than the others. If the tv is selecting different access points, it might be worth gathering some data. I do not know if the tv provides information about the WiFi signal. (My phone, for example, reports the WiFi band (2.4G or 5G) and the transmit & receive link speeds.)
The Orbi "app" provides a little information about the link speed. Each time after the tv connects, the Orbi should report which access point it is using and the link speed achieved. Are they similar (or different)?
To confess even more, I do not know if a tv being "off" really means OFF. It might not be displaying a picture or sound, but it could be "alive".
This is a real puzzle.
- ElfnashApr 25, 2021Tutor
I have not tracked the IP address each time. I guess that might be a clue if it is dismissing the connection and re-establishing a new one. So far the tv is the only device that I have had a problem with. When it switches, the connection between it and my phone when mirroring is messed up. It isn't the phone because it does the same thing with my iPad and iPod.
- CrimpOnApr 25, 2021Guru - Experienced User
Elfnash wrote:I have not tracked the IP address each time. I guess that might be a clue if it is dismissing the connection and re-establishing a new one. So far the tv is the only device that I have had a problem with. When it switches, the connection between it and my phone when mirroring is messed up. It isn't the phone because it does the same thing with my iPad and iPod.
The IP address should be the same no matter which access point it connects to. Orbi has a feature on the web interface to 'reserve' IP addresses for devices. It is entirely optional. Some people like to 'know' which IP address each device will have, and use this feature. For example, my thermostat is 192.168.1.10. It is never any other IP. My front door security camera is 192.168.1.52. and so on.
Would you be comfortable sharing which model of tv the phone (and iPad?) are mirroring to?
The tv is an LG 7000 series. I hav not contacted the tv manufacturer.
