roborbi
May 12, 2021Tutor
Orbi RBR50 No connection to ethernet wired devices
Firmware 2.7.2.104 MacOS computers. 3 or 4 days ago, my orbi lost connection with all of my ethernet hard wire devices. Has there been a recent firmware upgrade? I've noted that any hard wired de...
- May 17, 2021
All,
I have a final update on this issue.
Unfortunately I experienced the same weird IP address issues, even after switching out the RBR50 for the RBK852 router.
Going back to square one, I eventually tracked the issue down to a faulty ethernet connection on an old Blue-ray player in my entertainment system.
Hard to believe that one bad ethernet port could cause such havoc. While it didn't bring down the whole network, it did bring down any ethernet hard wired device on the network. Turns out that neither the Orbi nor an Orbi update was to blame.
So . . . after switching over to the RBK852, as I said, I was still having issues getting any internet connection on any device using ethernet.
The issue was hard to track down.
At first I thought I had lost the entire ethernet switch that was feeding my entertainment system. What I learned from CrimpOn earlier in the thread was that one bad ethernet connection was all it might take the throw things off. So . . . by slowly connecting and disconnecting one device at a time on the switch, I was able to narrow the issue down to the ethernet port on the Blu-ray player being the culprit. Hook the BR player up via ethernet and strange 168.254 IP addresses started appearing. Take the Blu-ray out of the loop and bingo, ethernet was working properly again.
Kudos to CrimpOn. This nugget of information from him also helped solve the problem:
>> 168.254 is a valid IP address, although not one that an Orbi would assign.
169.254 is an IP address that a device self-assigns to itself when it cannot reach a DHCP server.
It did not come from the Orbi. <<
Thanks CrimpOn for sticking with it, offering advice, and continuing to ask the right questions.
Also thanks to Furrye38 for his helpful suggestions and support. We are lucky to have this community of experts that is willing to offer their
time and support and show an interest in helping solve our problems. You have made me feel validated by not treating me like the novice I know I am.
Roborbi
CrimpOn
May 14, 2021Guru - Experienced User
Is this Orbi still within the one year warranty?
If more than one ethernet device fails to connect directly to the Orbi LAN ports (no switches, no cabling, no wall jacks, different ethernet cables), this is an obvious case for a warranty replacement.
From post #1, it appears that everything was working until recently, and this is not a case of "I updated firmware to 2.7.2.104 and immediately my LAN ports failed to work."
Although it is a chore and I see no logical reason why it should accomplish anything, there is no harm in manually loading a previous firmware on the Orbi, such as v2.5.2.4. That is:
- Save a copy of the current configuration.
- Download v2.5.2.4 for the router from the Netgear support site:
https://kb.netgear.com/000062319/RBR50-RBS50-Firmware-Version-2-5-2-4 - Also download a copy of 2.7.2.104 for the router
- Use the Advanced Tab, Administration menu, Firmware Update, Manual Update tab to load 2.5.2.4 on the Orbi router.
Do not do anything to the satellites. - When the router reboots after the firmware update, test the ethernet LAN ports before doing anything else.
- If the LAN ports now work, then it was something about the firmware.
- If the LAN ports continue to fail, then I fear a hardware failure.
roborbi
May 14, 2021Tutor
CrimpOn,
Unfortunately the unit is out of warrenty. More than a couple years old.
Thanks for the instructions on how to downgrade the firmware. I will consider.
I'm fairly certain the upgrade to the latest firmware happened 3 months ago however.
And up until 5 days ago all was working well.
My gut tells me it's a hardware failure.
Been looking for an excuse to go Wi-Fi 6.
I guess the orbi gods have answered. : > (
roborbi
- FURRYe38May 14, 2021Guru - Experienced User
Any chance you have a spare router? Something you can swap in to check this with a different router?
- roborbiMay 15, 2021Tutor
Yes. I have a new RBK852 Wi-Fi 6 unit arriving tomorrow. I'll let you know how the switch over goes.
roborbi
- roborbiMay 17, 2021Tutor
All,
Roborbi
