TimdF
Feb 21, 2022Initiate
Orbi RBR50, no connection with satelites anymore
Since 1,5 year I use an Orbi system with 3 satelites, never had any issues. But out of the blue (I have not changed anything) I only have connection via the router and the 3 other satelites are gon...
TimdF
Thanks! Hope I can answer them with my knowledge;
- The firmware on the router is V2.7.3.22
- Firmware satellites I can not see anymore, the app does not recognize them (see attached)
- Connected to the router of my provider (in bridge modus) via lan, lan and wifi via the Orbi router is working
- Not sure how I can re-sync, I tried via the sync bottom on the back of the units
- The app does not recognize the satellites anymore when I search for them
KevinLiT
Feb 21, 2022NETGEAR Moderator
Hello TimdF,
I understand you are having issues with your RBS50 syncing to your RBR50.
Please try the following:
1. First, Press and hold the Reset button until the Power LED on your RBS50 blinks amber.
2. Then, Bring the RBS50 and the RBR50 in the same room ( a few feet from each other).
3. Next, Press the Sync button on the router.
4. Then, Within two minutes, press the Sync button on each satellite.
Supporting Knowledge Articles:
RBR50 and RBS50 Reset: https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Syncing RBS50 and RBR50: https://kb.netgear.com/31018/How-do-I-sync-my-Orbi-router-and-satellite
Please let me know if this helps!
Best,
Kevin
Community Team
