Freway01
Aug 12, 2019Aspirant
Orbi RBR50 No Delivering Gigabit Service When Connected to a NetGear CM1200
Just upgrade to Cox's Gigabit service here in Gilbert, AZ. Purchased a Netgear Nighthawk CN1200 cable modem and hooked it up to my Orbi RBR50 router. One of the Ethernet ports connects to a Netgear G...
Aug 13, 2019Guru - Experienced User
Besure you post abou this in the main Orbi forum:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Freway01 wrote:Just upgrade to Cox's Gigabit service here in Gilbert, AZ. Purchased a Netgear Nighthawk CN1200 cable modem and hooked it up to my Orbi RBR50 router. One of the Ethernet ports connects to a Netgear GS116NA 16-port unmanaged switch. Connected to the switch are three PC's. When a run the Google speedtest from each of the PC's I never see anything above 750Mbps down.
Is the Orgi capable of Gigabit speeds? If so, what are some of the configuration settings I need to set on the Orbi to get Gigabit wired speeds?
