burlius
Apr 01, 2020Aspirant
Orbi RBR50 no internet on wired devices
I have an RBR50 with 4 satellites that were all working great for almost a year now. Yesterday for some reason, my internet quit working and was very intermittent. On the phone over an hour with my I...
burlius
Thanks for the quick reply, but I forgot to note that I have a brand new, unopened RBR50 that I tried initial setup to replace my current one and it did not solve the problem. I did not set this up through a direct connected PC. I did disable Circle but not Armor.
Apr 01, 2020Guru - Experienced User
So two differenct RBRs you can't get your PC connected too? if so, then I would try a different PC. Seems like your PC need to be looked at.
Be sure your using a good quality LAN cable.
Be sure your connecting the LAN adpter cable from the PC to the WHITE LAN ports in back of the RBR. Not the Yellow port.
If anything use a phone or pad with Orbi App to connect to the RBR and get one of them setup if you need.
