burlius
Apr 01, 2020Aspirant
Orbi RBR50 no internet on wired devices
I have an RBR50 with 4 satellites that were all working great for almost a year now. Yesterday for some reason, my internet quit working and was very intermittent. On the phone over an hour with my I...
burlius
I actually have 2 PCs and a laptop in the room. I've alternated between all 3 with intermittent to no success. Last night it seemed to be working and then failed. All 3 have different ethernet adapters. 2 of the PCs are ones that I built 3 months and 1 year ago. The laptop is a gaming laptop from Dell and I'm getting the same results. Right now, the Orbi is providing internet to most WiFi devices but not at all for some.
Apr 01, 2020Guru - Experienced User
So try a factory reset on the RBR by pressing the back reset button for 15 seconds then release.
Connect one wired PC to the RBR with the ISP modem disconnected from the RBR.
Can you access the RBR setup wizard at 192.168.1.1 in a web browser?
Check your networking adapter settings to see if the adapter is getting any IP addresses from the RBR. It should be getting a 192.168.1.something address.
