Matt526
Aug 09, 2018Follower
Orbi RBR50 No Internet
Hi! I have an Orbi RBR50 with 2 satellites. Its been working great for the past several months but the internet went out a couple of days ago. Our Internet provider gave us a modem router (AN5506-04)...
Aug 09, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
