VStarNinja
Jul 10, 2019Aspirant
orbi rbr50 no net or wifi when connected
Hello all, hope the community can help, ive got NBN internet, it was working fine untill last week, long story short, telstra replaced all the hardware, now my wifi routers would not connect ethernet...
Jul 10, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #3...
VStarNinja wrote:Hello all, hope the community can help, ive got NBN internet, it was working fine untill last week, long story short, telstra replaced all the hardware, now my wifi routers would not connect ethernet or wifi, i rang the phone company and done serveral test, they said the wifi router must be broken so i went out and bought the orbi rbs20, it would not still connect to the net via the routers, ive have tried everything i can think of, but when i connect the pc directly to the nbn modem the internet works fine, can somebody please help, i have called the phone company and have spoken to them for serveral hours and still could not solve this problem,
thanks in advance
- VStarNinjaJul 11, 2019Aspirant
sorry i dont know what firmware is on it, how do i find out?
i cant see any mfr, but the model is WNTD-CLI2
revision: R1D
the serial is 2.11.5323.180705
NTD UNI-CLIENT
there is no button on the NBN box, its connected directly to the satterlite disc, i cant disable wifi, it has 4 uni-d ports, port no1 is connected to my pc, with flashing green light at the port, port no2 is connected to orbi wifi router with no green light,
i tried to log into netgear but they said iam not connected to orbi wifi
i just rang telstra and ask them to bridge but they said they can only do it for telstra modems,
sorry iam a noob, i have tooken lots of photos but i dont have net on my phone to upload them on here
- CrimpOnJul 11, 2019Guru - Experienced User
What happens if you connect the Orbi to port 1 instead of the PC (and maybe restart the modem so that it recognizes a new MAC address)?
- FURRYe38Jul 11, 2019Guru - Experienced User
Modem Combo Units:
Couple of options,
Try option #3...The ISP modem needs to have it's wifi disabled if at all possible. Ask your ISP to help you with this.
VStarNinja wrote:sorry i dont know what firmware is on it, how do i find out?
revision: R1D
NTD UNI-CLIENT
- VStarNinjaJul 12, 2019Aspirant
i went and bought a telstra modem, it seems to work when i wired it directly to the ethernet port on the orbi but doesnt work when its in the internet port, my phones and tv has wifi accept for the laptop, its connected directly to a lan port on the telstra modem, i tryed to switch to wifi so i can log in netgear but its not working, ive dl the netgear app but it says incorrect wifi mobile router, this router is not supported by netgear app, i have loged in the past with my laptop to block some device from using my wifi but cant seem to do it now, keeps telling me to connect to the orbi wifi network
