VistaGrande
May 18, 2020Tutor
Orbi RBR50 Non responsive, won't factory reset
After two years of working flawlessly my Orbi RBR50 router stopped working. I have two satellites RBS mdels connected to it. The power light is on and it is green. I tried to cycle the power - did...
May 18, 2020Guru - Experienced User
You might need to try tftp to recovery it.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
TomHarker
Jun 13, 2020Initiate
Heya,
I have the same problem, recently got a 2nd hand RBK50 set to upgrade from my perfectly good RBR40.
When powered up both the RBR50 and RBS50 have solid green power LED, and soild white ring lights.
I'm concentrating on the RBR50 for now to get that running first, I've tried a factory reset, a 30-30-30 reset and flashing the firmware back to v2.2.1.212 over TFTP (this fails halfway through the upload).
After all this I now have a flashing green power led and a solid white ring on top of the RBR50, and a deep sense of frustration!
Not sure where to go from here??
