VistaGrande
May 18, 2020Tutor
Orbi RBR50 Non responsive, won't factory reset
After two years of working flawlessly my Orbi RBR50 router stopped working. I have two satellites RBS mdels connected to it. The power light is on and it is green. I tried to cycle the power - did...
PeterSchneider
Oct 05, 2020Star
Having exactly the same issue. All working fine and then suddenly dead to the world. Solid green on power but no response to reset attempts. Very frustraiting.
Has anyone recovered from this or am I dreaming to think that there is a way to fix this very expensive brick?
Oct 05, 2020Guru - Experienced User
Try this:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
I had a problem on a Windows 10 PC where this didn't work to use TFTP, so I switched to a WIndows 7 PC and the TFTP worked.
- PeterSchneiderOct 05, 2020Star
I try the tftp and get an error with the -i option flag. Mine is a Mac and no Windows machine to work with.
The fact that I never get to a flashing yellow/amber power light is also concerning.
- FURRYe38Oct 05, 2020Guru - Experienced User
Possible the RBR is bad. Something to contact NG support about to see what your options are at this point.
- KurtsterMay 01, 2021Initiate
After 15 years using Netgear I'm throwing in the towel. I have the same problem here with my RBR50. No moving parts but it just stopped working. Green solid light on the power no matter how many seconds I hold down the button. White flashing ring light no matter what I do. Unable to TFTp anything because it perpetually stays in a mode where it's booted up and won't look for FW updates.
Just bought an Eero WiFi 6 system today. So far so good!
- brightmanpMay 26, 2021Initiate
My RBR50 and RBS50 have been rock solid for almost 14 months since I purchased them for the pricely sum of £249.99 from Amazon.
However I too have been plagued by this issue. It first started 3 weeks ago late in the evening (12:34 am) where after much frustration I was able to use a TFTPD client to flash the firmware to an older version. This seemed to do the trick and I was a happy camper again working merrily taking part in the many MS Teams calls my life consist of nowadays. However this has now happened again (Again late in the evening - 10:30 pm ish) and only this time it's left the RBR in permanent state of booting up (constant white pulsing, with green power led). All attempts to factory reset or flash the firmware to an older version are failing to have any impact, it simply ends up in a permanent white pulsing state with green power LED.
I find it incredibly frustrating that such expensive equipment should fail for no apparent reason and dubiously not longer after the warranty expiry. What really rubs the salt in the wound is i've been so impressed with the RBR50 model i've advised 2 other family members to acquire them, let's hope they don't end up in the same position just after their warranty expiry!!
I will now be voting with my feet and never buying Netgear equipment again and advising my friends and family to do the same.
Disgruntled of Ipswich.
