VistaGrande
May 18, 2020Tutor
Orbi RBR50 Non responsive, won't factory reset
After two years of working flawlessly my Orbi RBR50 router stopped working. I have two satellites RBS mdels connected to it. The power light is on and it is green. I tried to cycle the power - did...
Mar 14, 2021Guru - Experienced User
So you can't access the RBRs web page after a 15 second press of the reset button then release?
Try the TFTP option mentioned in this thread?
stilesfamily wrote:I have this exact same issue. Any other ideas on how to fix it???
CrimpOn
I have used TFTP several (stressful) times. It seems as much an "art" as it does a "science".
My impression is that there is a magic window of time during which the router will accept a TFTP connection. Maybe only a few seconds. I had numerous attempts fail (0 blocks transmitted), and then one succeed.
