VistaGrande
May 18, 2020Tutor
Orbi RBR50 Non responsive, won't factory reset
After two years of working flawlessly my Orbi RBR50 router stopped working. I have two satellites RBS mdels connected to it. The power light is on and it is green. I tried to cycle the power - did...
lrkell01
Oct 16, 2021Aspirant
Same problem on my Orbi that's a little over 2 years old. Technical support says its a hardware failure and that I need to buy a new one. With such a lousy quality product, I surely won't buy a Netgear product again.
Oct 16, 2021Guru - Experienced User
Good luck then.
