Renacomp
May 26, 2020Follower
Orbi RBR50 not allow Granstream HT801 to register
I have had the GRandstream working with my old optus modem router, i changed to the ORBi and now it will not work.
Has anyone had this issue before,
ORBI RBR50 firmware V2.5.1.8
Grandstream HT801 firmware 1.0.19.8
What is the Orbi connected to? (brand & model)
Is the Orbi is "router" or "access point" mode?
Was the previous Optus modem/router an "all in one" device?
Have you looked at the installation steps describing NAT?
Are you using same SSID name and password on the Orbi as you did on the prior router?
Renacomp wrote:I have had the GRandstream working with my old optus modem router, i changed to the ORBi and now it will not work.
