awhipple11
Apr 20, 2021Tutor
Orbi RBR50 Not Connecting
I have the RBR50 mesh system and it will not work properly after working perfectly for 2+ years. I've done the reset 5+ times and still have no luck. It says it's connected but when I go do a speed t...
Apr 20, 2021Guru - Experienced User
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
awhipple11 wrote:I have the RBR50 mesh system and it will not work properly after working perfectly for 2+ years. I've done the reset 5+ times and still have no luck. It says it's connected but when I go do a speed test it says its at 2.0 Mbps. No webpages will load, apps, etc.
Any suggestions or is the system dead?
Thanks!
awhipple11
Apr 20, 2021Tutor
Yes, I have done a factory reset probably 5 times today. It reconnects but the internet is still not functioning properly.
- mrputtputtApr 20, 2021Tutor
you may have same problem as me. i just bought a new one to remove the possibility of any hardware issue on any machine i have. oddly while i cannot go to the router via 192.168.1.1, everything is connecting accordingly.
That's why i spent hours (3 hrs at one point) troubleshooting this with mulitple restarts of ISP modem & router. And doing a new "setup" via mobile app before 30-30-30 reset and one 15 sec reset push also.
Very disappointed it only lasted 2 yrs. But it is what it is and I'm hoping the replacemeent lasts longer since I have no AX devices to leverage a new router for and start over in a sense.
- awhipple11Apr 20, 2021Tutor
mrputtputt wrote:you may have same problem as me. i just bought a new one to remove the possibility of any hardware issue on any machine i have. oddly while i cannot go to the router via 192.168.1.1, everything is connecting accordingly.
Yea, it's disappointing for sure. I just bought mine in January of 2020. It worked great until a couple days ago.
- FURRYe38Apr 20, 2021Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT?
Did you power OFF the Modem/ONT for 30 seconds then back on when you reset the RBR?
awhipple11 wrote:Yes, I have done a factory reset probably 5 times today. It reconnects but the internet is still not functioning properly.
My wifi provider is COX. I don't know the model number of the modem that they provided but it is just the one that they provide when you sign up for internet. Yes, I've done plenty powering off and on while resetting.
FURRYe38 wrote:What is the Mfr and model# of the Internet Service Providers modem/ONT?
No idea what that would be. Model# would be helpful. You sure it may not be the ISP services? They are known to have some problems or odd service outages as well. Something to check on to be sure. Any wifi router depends on good signal from the modem.
I guess revert back to what you had working on the RBR and RBS. Downgrade the RBS first then RBR lastly.
awhipple11 wrote:My wifi provider is COX. I don't know the model number of the modem that they provided but it is just the one that they provide when you sign up for internet. Yes, I've done plenty powering off and on while resetting.
