Freway01
Aug 13, 2019Aspirant
Orbi RBR50 Not Delivering Gigabit Service When Connected to a NetGear CM1200 Cable Modem
Just upgrade to Cox's Gigabit service here in Gilbert, AZ. Purchased a Netgear Nighthawk CM1200 cable modem and hooked it up to my Orbi RBR50 router. I have a wired house so besides the Orbi route...
Aug 13, 2019Guru - Experienced User
Factory reset the RBR and setup from scratch with a wired PC. Don't connect any other devices or RBS at this point. Don't enable QoS, Traffic meter or Access controls on the RBR. Just setup and run a speed test with the wired PC connected to the RBR using Ooklas installable speedtest app in Windows or Mac.
Seen issues with RBR not getting near 900Mbps:
Some have been able to see near 900Mbps with the Orbi system with wired connections:
https://community.netgear.com/t5/Orbi/New-RBR50-Satellite-setup-some-thoughts-and-questions/m-p/1695161/highlight/true#M50762
https://community.netgear.com/t5/Orbi/Download-speed-cut-in-half-on-wired-connection/m-p/1695372/highlight/true#M50815
You'll not see much over 500Mbps with most wireless devices. Some newer ones maybe. All depends on client hardware support and Mfr design.
