grify
Dec 20, 2019Aspirant
ORBI RBR50 not honoring reserved IP addresses
ORBI RBR 50 running 2.3.5.30 I have configured a reserved IP for my Raspberry Pi which is a server, but every reboot, the IP address of the raspberry pi changes the mac address isn't the prob...
grify
Dec 25, 2019Aspirant
There doesn't appear to be a etc/NetworkManager
I'm going to test another reboot to confirm if the MAC address is actually changing.
Pre-reboot of router and pi:
(according to OrbiLogin.com basic Attached Devices)
connected to orbi Orbi Satellite-1 (B0:39:56:7C:A1:AD)
Wired
MAC Address is B8:27:EB:AD:4A:6B
IP is 192.168.1.10
Post-reboot of router and pi:
Orbi Satellite-1
B0:39:56:7C:A1:ADWired
B8:27:EB:AD:4A:6B
IP is 192.168.1.14
grify
According to the Attached Devices page, the IP was changed (from .10 to .14) despite the fact that the MAC remained as
B8:27:EB:AD:4A:6B
- CrimpOnDec 26, 2019Guru - Experienced User
A solution to this issue eludes me. Given that the Orbi has an IP address assigned to this MAC address in the LAN Setup table (Advanced Tab, Setup), it should get the same IP address every time. Provided, of course, that there was not a different computer already using that IP address when the DHCP request came in..
Maybe it is time to capture the DHCP packets that are passing between the Pi and the Orbi. One way to do this is to go into the Orbi "debug" screen, Enable LAN/WAN Packet Capture, then click on Start Capture:
Then power up the Pi, check which MAC and IP it gets.
Do a restart & check again.
Do this a couple of more times.
Then go back to the debug page and "Save Debug Log". This will put a zip file on whatever computer you are managing the Orbi from.
The zip file has LOTS of stuff in it. Unzip it and then use Wireshark (or something like it) to open the LAN file.
Filter the output on "DHCP" and it should show all the interactions between the Pi and the Orbi.
- grifyFeb 13, 2020Aspirant
I can't find the Orbi "Debug"
I just need to enable websocket traffic on ports 25517 and 25317 to my raspberry pi
- michaelkenwardFeb 13, 2020Guru - Experienced User
Go to the address you use to get at the browser graphical user interface (GUI).
Turn it into
http://{url}/debug.htm
