agingproduct
Jun 10, 2020Guide
Orbi RBR50 not reporting bandwidth to Peak Hour 4
Hoping someone can help. I have the Orbi RBR50 with two sattellites setup at home. I am using an application called Peak Hour 4 on my mac to monitor traffic through the main router which worked for a...
- Nov 23, 2020
I upgraded to firmware version v2.6.1.40 a few days ago and it seems to have resolved the problem. The fix must be bundled in this version (hopefully).
agingproduct
Jun 12, 2020Guide
Is there a reason why my posts are being chopped?
CrimpOn
Jun 12, 2020Guru - Experienced User
agingproduct wrote:Is there a reason why my posts are being chopped?
I have no idea about posts, however...
- My search for "Netgear router SNMP" leads me to conclude that NO Netgear residential routers support SNMP.
None. Zero. Not any. - Orbi claims to support UpNP, but there is no documentation to indicate which features of UpNP are supported.
My guess is that "traffic reporting" is not supported.
It would have been really helpful if the software vendor had some sort of list of "routers that work" and "routers that do not work".
Does not seem like that big a project.
What they do instead is say, "Use our 10 day free trial and quit if it doesn't work."
Bummer
