Dave_G20
Oct 07, 2018Aspirant
Orbi RBR50 not resetting password and UID on paperclip reset
I have tried everything with the paperclip on my RBR50. Until it turns orange and blink, until it turns orange, until it goes back to green. Turning it's pwoer on and off, unplugging devices, and it...
Oct 07, 2018Guru - Experienced User
Can you log into the routers web page and go to Advanced Tab/Advanced/BackUp and select ERASE. Then once this process starts, clear ALL browser caches, exit the broswer and re-open the browser and navigate to 192.168.1.1 or orbilogin.com and walk thru the setup wizard.
Try different browsers, like IE11, FF or Opera.
- Dave_G20Oct 07, 2018AspirantThat would work if I could get into that page. Which I need the password and userID to do.
- Dave_G20Oct 07, 2018AspirantThat would work if except I need the password and userID to get there...
- FURRYe38Oct 07, 2018Guru - Experienced User
When using the reset pin hole and holding it until the top turns on AMBER and let go. Did you clear browser caches and exit and reopen the broswer while the router reset? Try a diffrent browser?
- Dave_G20Oct 07, 2018AspirantI cleared the cache and reopened the bbrowse but that didn't help. I finally did get it. apparently it didn't change or accept the capitalization on the user ID (I had it set to ADmin - wrote it down and it apparently wanted admin along with the old password) the funny part is it asked different security questions than when I set it up, so I couldn't give the answers to it. At any rate it will work well enough like this. Thanks for the quick responses...
