winsrfr
Sep 30, 2018Aspirant
Orbi RBR50 not talking to Network Solutions website
My Orbi RBR50 has stopped talking to my website provider, Network Solutions on Friday afternoon. I can't access my website builder tool nor can I check my email. Very frustrating. I can get to my ...
Sep 30, 2018Guru - Experienced User
Was it working before? if so, and you didn't change anything on the Orbi, I presume the issue would be a web site service issue, not a Orbi issue.
What is the Mfr and model# of the IP modem the Orbi is connected too?
winsrfr
Everything was working great Friday morning. Now, everything works as usual with every other site except this one
- FURRYe38Sep 30, 2018Guru - Experienced User
If other sites and such work and this one site doesn't, it wouldn't be a router issue.
- winsrfrSep 30, 2018Aspirant
I have been reading other posts where people are having the same issue as me. I can hook my computer directly to my cable modem with a LAN line and it works perfectly. As soon as I hook my LAN line from modem to router and a line from router to computer, it's a no go for only that 1 site.
modem is an Arris CM820
Try a power off of the modem and Orbi router for 1 minute, then back on.
Might try a full reset on the Orbi router and setup from scratch....
