winsrfr
Oct 01, 2018Aspirant
Orbi RBR50 not talking to Network Solutions website
My Orbi RBR50 has stopped talking to my website provider, Network Solutions on Friday afternoon. I can't access my website builder tool nor can I check my email. Very frustrating. I can get to my ...
winsrfr
modem is an Arris CM820
Oct 01, 2018Guru - Experienced User
Try a power off of the modem and Orbi router for 1 minute, then back on.
Might try a full reset on the Orbi router and setup from scratch....
- winsrfrOct 01, 2018Aspirant
all done. nothing helped
- FURRYe38Oct 01, 2018Guru - Experienced User
Try different PC?
Contact this web site for help and information regarding this...again, if other sites work and this one doesn't, possibe site sevice isssue or DNS issue.
Try using 1.1.1.1 and 9.9.9.9 DNS on the router.
actually might not have done a full reset on the Orbi. How is that done?
and even my iphone can't get emails from my website when I am on the Orbi wifi
Hold the reset button on the router til the top LED turns on Amber or use the Web UI under Admin/Backup to do a reset. Either one will work.
Thanks. I'll try that
You can add custome DNS to the router by it's web page. I believe under Advanced tab/Internet Setup...
- schumakuOct 01, 2018Guru - Experienced User
If your ISP does run a DNS cache, also negative results will remain cached for a certain time - these DNS caches won't do new queries for a while. As the routers pick up the ISP supplied DNS servers commonly, they just reflect what's there - or not.
Seriously, I don't think a consumer router DNS queries (implemented by dnsmasq) does fail or block a single domain only.
Not very difficult to check, just figure out the DNS servers configured. query these for the domain the www, the mail, smtp, pop, whatever in question. Then compare e.g. to the big public DNS, example is using google.com:C:\> nslookup
> server 8.8.8.8
Default Server: google-public-dns-a.google.com
Address: 8.8.8.8> google.com
Address: 8.8.8.8Non-authoritative answer:
Addresses: 2a00:1450:400a:801::200e
172.217.18.14> server 1.1.1.1
Default Server: one.one.one.one
Address: 1.1.1.1> google.com
Address: 1.1.1.1Non-authoritative answer:
Addresses: 2a00:1450:400a:802::200e
172.217.168.46Instead of the 1.1.1.1 or the 8.8.8.8 enter a) the router LAN IP, and b) the ISP supplied DNS and query your domain.
