Stlfanrph
Sep 09, 2022Aspirant
Orbi RBR50 not working
I purchased my Orbi from Best Buy in July 2019. I haven’t had any issues until last night when it went out and basically disabled my entire home. Since we switched over everything during the pandemic ...
CrimpOn
Sep 09, 2022Guru - Experienced User
Stlfanrph wrote:
It has a slow blinking white light after I reset it. I get an error if I try to reboot, reconnect or try to upgrade.
How are you attempting to administer the router?
- web interface?
- Orbi 'app'?
What device is showing an error? can you please describe the specific message?
- StlfanrphSep 10, 2022AspirantThrough the Orbi app. The Orbi is showing the error. It’s saying that it cannot connect. It’s hooked up to our Fios router. Which is working fine. We love the Orbi too but it just went dead.
- ekhalilSep 10, 2022MasterI guess that the blinking white light you see is on the Orbi satellite? Is the Orbi router working fine? How many satellites do you have and do you see the same issue on all satellites? Screenshots from what you see on the Orbi app would help us understand the issue please.
- KevinLiTSep 12, 2022NETGEAR Moderator
Hello Stfanrph,
Welcome to the NETGEAR Community!
I understand that your RBR50 is unable to reboot or upgrade through the Orbi app. Are you able to access your Orbi through Orbilogin.com?
Best,
Kevin
Community Team
