cwise
Aug 14, 2019Aspirant
Orbi RBR50 occasionally doesn't route Internet traffic
Fairly frequently my Internet access will stop working whether wireless or wired. Nothing will load, though whatever device I'm on shows I'm still connected to the local network and can access the Or...
ekhalil
Aug 14, 2019Master
This can be related to the ISP Lease Time issue:
- When this issue happens, what would you see in the web GUI under >> ADVANCED >> ADVANCED Home >> INTERNET PORT >> CONNECTION STATUS. What are the values for “Lease Obtained” and “Lease Expires”?
- Will disconnecting the internet cable from Orbi’s WAN port and connecting it again resolve the issue?
- cwiseAug 14, 2019AspirantRight now (though I am not currently having the issue) I see Lease Obtained 0d 8h 0m and Lease Expires about 5h, which would make sense since I rebooted about 3h ago.
I will report back when I have the issue again. Thanks for your really quick response.- ekhalilAug 18, 2019Master
I will report back when I have the issue again. Thanks for your really quick response.How is it going? :)
