cwise
Aug 14, 2019Aspirant
Orbi RBR50 occasionally doesn't route Internet traffic
Fairly frequently my Internet access will stop working whether wireless or wired. Nothing will load, though whatever device I'm on shows I'm still connected to the local network and can access the Or...
cwise
Right now (though I am not currently having the issue) I see Lease Obtained 0d 8h 0m and Lease Expires about 5h, which would make sense since I rebooted about 3h ago.
I will report back when I have the issue again. Thanks for your really quick response.
ekhalil
Aug 18, 2019Master
How is it going? :)
- cwiseAug 19, 2019Aspirant
ekhalil wrote:
How is it going? :)If it has happened in the past few days, it's happened when I wasn't home. Once it inevitably does, I'll hurry back to let you know. :-)
- ekhalilAug 22, 2019Master
cwise wrote:If it has happened in the past few days, it's happened when I wasn't home. Once it inevitably does, I'll hurry back to let you know. :-)
Have you seen the issue again? Could you get the lease time values as explained?
- cwiseAug 26, 2019Aspirant
Naturally, I haven't seen the problem since I asked this question, despite it happening consistently for months prior.... Hopefully that's a new normal, I guess.
If/when it does happen again, I'll be sure to report back with the lease info. Thanks to everyone for replying so quickly to help me out!
