cwise
Aug 14, 2019Aspirant
Orbi RBR50 occasionally doesn't route Internet traffic
Fairly frequently my Internet access will stop working whether wireless or wired. Nothing will load, though whatever device I'm on shows I'm still connected to the local network and can access the Or...
cwise
Aug 20, 2019Aspirant
My ISP modem is an Arris TM1602A.
I have not performed a factory reset on the Orbi
since I set it up a couple months ago. I think there have been two firmware updates since then. Is it considered good practice to do that after every FW update?
Aug 20, 2019Guru - Experienced User
If you run into odd issue, yes, a reset and setup from scratch maybe needed. After the reset, I would set the default DHCP IP address pool size to 192.168.1.100 thru .200.
I would power OFF the iSP modem for 1 minute while the Factory reset happens on the RBR. Then walk thru the setup wizard on the RBR.
